Thread: Pool Forum is an old friend.
    Jul 2012
    Northern WA state
    Red face Pool Forum is an old friend.
    3 years ago I got invaluable help with solving the issues I had with an Intex 16'x42" pop-up pool.We have well water with rust fungis.I was able to clear up the water using household bleach but I can't remember how many gallons I dumped in it initially and how often I checked the chlorine levels first few days. I know that you folks are real busy this time of year so can you tell me where I can find the info.,It will be much appreciated.
    TY Snowbankwoman
    Default Re: Pool Forum is an old friend.
    Bleach will tend to drop your iron out -- where it will either (a) drop to the bottom, (b) stain things, (c) come out on the filter, or (d) all 3. Filtering and vacuuming will then clear everything except the stains.
    A 16' pool with 2.7' water depth holds about 4,000 gallons with a PF=30, so a gallon of 6% (check the %) PLAIN household bleach will add about about 15 ppm (0.5 lbs Cl2/gal of 6% bleach x 30). Adding a single large dose of bleach via, circulating it, and then letting it sit overnight may well drop it all as rust dust to the bottom of your pool. That's easy to clean up IF you have a way to vacuum.
  1. New pool & new to forum
    By Neiks in forum General Interest
    Last Post: 06-21-2013, 06:10 PM
  2. My friend is giving me a hard time about Clorox
    By adesalvo in forum Using Chlorine and Chlorinating Chemicals
    Last Post: 06-09-2010, 05:11 AM
  3. Trying to help a friend
    By Sumo1 in forum In-Ground Pool Construction and Repair
    Last Post: 11-18-2008, 02:25 PM
  4. A new pool forum
    By SeanB. in forum General Interest
    Last Post: 04-15-2008, 02:50 PM
