Results 1 to 8 of 8
Thread: Adding Cyuranic Acid to Sand Filter?
    Ontario, Canada
    Default Adding Cyuranic Acid to Sand Filter?
    Had to replace the liner in my pool so I am starting fresh.
    AquaRite manual says I need 80 ppm of CYU, I figure 3kg should do the trick for now.
    Question is how do I get 3kg of CYU into my pool?
    Do I just mix it in a bucket of warm water and then pour it into the pool?
    Don't really like the idea of adding it to my skimmer since I don't want to clog up the impeller in the pump. Could I just open the sand filter and pour it in that way?
    I.G. Vinyl Pool 12' by 24' approx 10,000 gal, Hayward Sand Filter, 3/4 HP Hayward Super Pump, Hayward Aqua Rite Salt Generator, T-15 Cell.
    Default Re: Adding Cyuranic Acid to Sand Filter?
    I always just pour mine slowly into the skimmer and never have a problem. Alternately, you can put it in an old sock and hang it in front of a return jet. If you give it a squeeze once in awhile, it will help it dissolve faster.
    May 2010
    Another method is to fill a 5 gallon Home Depot Bucket with pool water, add the CYA and cover it for a few days, stirring or mixing it every once in a while. Then pour off the disolved liquid directly into the pool, being careful not to dump the undisolved granules into the pool. Then re-fill the bucket with more pool water to dissolve the remaining granules. Repeat as necessary untill all disolved.
    Lehigh Valley, PA
    I just bought some CYA today to replace what I lost with the leak. I noticed that the granules are much smaller than the previous bucket I had. I like BTG's method of pre-dissolving in a bucket. This batch actually dissolved very quickly . . . in less than an hour with a little stirring now and then. Granted, I didn't have to add 6 pounds but still, the smaller granules help make it dissolve better.
    Virginia
    I also just add it slowly directly into the skimmer and have never had a problems (pool installed in 2004).
    Sep 2011
    Central NJ
    Ive found a good method that seems to work quickly.
    I take a mens dress sock (shh my wife doesnt know) and fill with the cya you want to add. I take the top off my skimmer and feed the top of the sock thru the hole in the skimmer top. While holding the top of the sock, I put the top back on the skimmer to measure how long I need the sock to be to be in the flow of water, then tie a nice knot.
    Takes about a day to go through 1.5lbs of conditioner this way. No need to squeeze or mess with it and easy to check.
    24' Round 52" (44"/12450gal) Deep Namco Morada - ClearWater 22" Sand Filter - 1.5HP (SPL) Speck Pump - Taylor K-2006C Test Kit
    That's kinda the way I added my CYA this spring. Put it in an old sock and laid the sock in the skimmer basket and then kept the pump running 24/7 until it was gone.
    If you run the pump 24/7 it doesn't matter much how you add it. It will usually dissolve in about 48 hours (or at least enough of it to protect your chlorine) I just pour it SLOWLY into the skimmer with the pump running. It's the easiest way.
    Last edited by Watermom; 07-24-2012 at 11:16 PM. Reason: make quote appear correctly
  1. Adding DE to a sand filter
    By AnnaK in forum Pool Equipment & Operations
    Last Post: 07-18-2012, 07:50 PM
  2. Adding DE to sand filter
    By The Raddish in forum Pool Equipment & Operations
    Last Post: 06-04-2008, 05:36 PM
  3. Replies: 5
    Last Post: 06-01-2007, 10:03 AM
  4. Adding DE to sand filter FAQ
    By Unabomber007 in forum Pool Equipment & Operations
    Last Post: 09-25-2006, 08:59 AM
  5. Adding DE to sand filter
    By The Raddish in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 07-28-2006, 05:14 PM
