Re: Adding Cyuranic Acid to Sand Filter?
Watermom
and then kept the pump running 24/7 until it was gone.
If you run the pump 24/7 it doesn't matter much how you add it. It will usually dissolve in about 48 hours (or at least enough of it to protect your chlorine) I just pour it SLOWLY into the skimmer with the pump running. It's the easiest way.
Reason: make quote appear correctly
