Thread: Going on Vacation for a week how do I leave my pool?
    Default Re: Going on Vacation for a week how do I leave my pool?
    RVJames --- I moved your post into its own thread. It is better not to try and give advice for more than one pool within the same thread. You can find yours here;
    http://www.poolforum.com/pf2/showthr...-leave-my-pool
    Jun 2012
    New Jersey, USA
    I do have trees that are constantly dropping debris in the pool which is why I cover it every night. I'd rather not have to ask someone to mess with it while I'm gone. Could I just add the bleach before I leave and then and when I get back?
    Lehigh Valley, PA
    That's what I did last year when I was gone a week: I raised the chlorine to FC=20 ppm, then put the solar cover on and folded one small section over to expose water, maybe 4 sq ft. My pump is on a timer to run 6 hours at night. When I came back I still had 8 ppm chlorine and a clean pool.
    The worse thing that can happen is that you have a little algae but if that is the case, we can help you clean it up.
