Thread: low chlorine w/ saltwater system
    Jul 2012
    Washington state
    Default low chlorine w/ saltwater system
    I have a new 16x48 intex above ground pool and my chlorine is low. Should i run boost or add bleach and if i add bleach how much should i add?
    Default Re: low chlorine w/ saltwater system
    We need a current set of water testing results taken with a drops-based kit to be able to advise you. Do you have a kit? If so, what kind? What all have you added to the pool, meaning ingredients and not just "shock."
    Please fill in your pool's information into our pool chart as that makes it easier for us to help.
    Pool Chart Entry Form
    Pool Chart Results
    Are you aware that those Intex SWCGs add copper to the water? You do NOT want copper in a pool. It is copper and not chlorine like everyone thinks that stains things and turns blonde hair green! If you unhook the copper electrode, you'll be doing yourself a big favor and avoiding some problems later.
    Welcome to the Pool Forum!
    Add bleach!
    Running boost shortens the life of your SWCG; they really work best MAINTAINING chlorine levels in pool water that's in good conditions, then they do cleaning up messes.
    Getting a good testkit can help us . . . and YOU . . . figure out WHY it's running low.
    + Here are links to the kits we recommend:
    HTH 6-Way Test Kit @ Walmart
    Taylor K2006A (3/4 oz bottles) @ Amazon
    Taylor K2006C (2 oz bottles) @ Amazon
    Your pool has PF of 27, so each gallon of 6% bleach will add about 13 ppm of chlorine to your pool. If it's low, but there's no slime on the sides or visible algae, add 1/2 gallon of PLAIN big-box store brand* 6% (check the %) bleach. If the sides feel slippery, or there's algae add 1 to 1.5 gallons.
    *PLAIN Clorox brand bleach is fine, but you have to be careful to avoid all the various gooped up versions of Clorox, so we no longer recommend it -- we've had too many people end up with soapy pools because they got one of the gooped-up versions of Clorox.
    May 2012
    Oklahoma
    I can confirm EXACTLY what Watermom said.....you will get green hair with blondes from your Intex SWCG system. I now run mine only for 1 hour a day just because. I generally add one cup of Clorox to the pool each week to keep my numbers perfect. I will not be using it anymore after this year is done. Putting it on boost will only serve to bring more copper in the pool and more green hair (if you have that problem.....I got alot of blondes around here..)
    Use PoolDocs links above to get the Taylor kit (I use 2006C) if you don't already have one.
    Bob E.
    Intex 10' x 30" metal frame pool, Intex 2500 gph filter/pump, Intex Saltwater generator, SwimMax 11KW heater, 2 x Small Game Solar Domes.
  1. advice on start up with saltwater system
    By fishlips in forum Pool Chemistry for Intex-type Pools
    Last Post: 06-28-2013, 05:11 PM
  2. Doughboy AGP and an Intex Saltwater system?
    By Drpepper in forum Salt Generators (SWCG) & other Chlorine Feeders
    Last Post: 06-28-2011, 02:33 PM
  3. Intex saltwater system
    By LeeDavenport in forum Salt Generators (SWCG) & other Chlorine Feeders
    Last Post: 05-31-2011, 07:31 PM
  4. Intex saltwater system
    By chasamp in forum Salt Generators (SWCG) & other Chlorine Feeders
    Last Post: 05-31-2010, 10:31 AM
  5. Pros and Cons of a Saltwater System
    By writer in forum Salt Generators (SWCG) & other Chlorine Feeders
    Last Post: 09-03-2007, 12:31 PM
