Thread: Intex Owner 15' x 48" overwhelmed
    Default Re: Intex Owner 15' x 48" overwhelmed
    Your numbers don't look bad except you need to get some chlorine in there. Since your CYA is also low, you may want to use dichlor for a short time as it will add CYA and chlorine at the same time. If you prefer to just use bleach, you can just add some CYA separately. You'll want a CYA reading of 40-50. Your pH is ok at 7.2 but if it goes any lower, you'll want to use some 20 Mule Team Borax to bump it up. Keep pH between 7.2-7.8. Alk and CH are fine.
    Take a look at this thread. It may be helpful for you.
    http://www.poolforum.com/pf2/showthr...p-routine-care.
    Jul 2012
    Merrimack, NH
    Watermom,
    Thanks.
    I was getting a little overwhelmed reading all the info that comes with the taylor test kit.
    I was getting a little to wrapped up with getting the water "balance".
    I plan to "shock" the pool with bleach, to bring up the FC and burn off the CC if I understand what I have been reading correctly.
    Do they make a liquid for CYA? I have the powder which I have been putting in a sock and then suspending in front of the return. The powder takes a long time to dissolve.
    Also, where in a store like walmart would I find the borax? I know they make a laundry soap, but I don't believe that is what I am looking for.
    They do make a liquid CYA but it is quite expensive. I always just buy the granular.
    You can find Borax in the laundry aisle at Walmart. 20 Mule Team Borax is what you are looking for. (It is in the laundry aisle but is not soap.)
