Re: Pristine blue to chlorine
Thanks...
I got a kit and here are my results...ph 7.5, cl 1, br 2, hardness 80 ppm, alkalinity 90ppm...and my water is clear and beautiful!
But here is the one you were mentioning...(by the way you are sooo correct!) i could NOT get the cya to turn cloudy so i could not get a reading...so I'm guessing my CYA is too low and that is why I can't get the chlorine level up????
Thanks for the info about "shock" I will NOT add the jug of "Shock" that the pool store sold me with my pristine blue. ( I called it shock b/c that is what is on the label but I am listening and I do understand now that shock is a process not a product.)
So please tell me what to do now..
