Thread: 0 Chlorine in pool!! HELP!!!
    Jul 2012
    Texas
    Default 0 Chlorine in pool!! HELP!!!
    I am a pool newbie, I'm sure y'all can tell by my name. I am also a very frustrated newbie!! I feel like it's mainly my fault for not researching way before putting up our pool, but anyways to get to the point, I have a 18 x 48 intex ultra frame above ground pool, we just set it up Thursday and finished filling it up yesterday. The only thing I have done is put a 3 inch chlorine tablet in the skimmer basket. I didn't know if it was safe to put shock in the pool while having a chlorine tablet in the skimmer basket so I haven't shocked it yet. I have tested twice using the strips that come with the hth starter kit, and both times the free chlorine shows 0, my ph and alkalinity both show a little high. I really don't know what to do, I'm very confused, and I need help because I have close to 20 people coming out to my house in a couple hours and they are expecting to be able to swim in the pool!!! PLEASE HELP ME!!!! :/
    Default Re: 0 Chlorine in pool!! HELP!!!
    If you don't have stabilizer in the pool (aka CYA), the sun is going to burn off the chlorine about as fast as the trichlor puck can put it in. With zero stabilizer, you need to be keeping 1-3 ppm of chlorine in the pool at all times. If you can tell me the volume of your pool in gallons or the dimensions (do you mean 18 foot diameter round pool, 48 inches deep? Or do you mean 18 feet wide, 48 feet long, and how deep?) then I can tell you how much plain, unscented bleach you need to get in the pool for it to be safe to swim in today. (48ft x 18 ft is a huge pool for ABG, but you're expecting 20 people, so maybe it's reasonable?).
    If the pool is clear, and you can get the bleach in the pool, then it's okay to swim for tonight. You'll need to add more chlorine after the people get out, though, because "people goo" is liable to use up what you put in there to begin with. Here's where you need something other than strips, which aren't reliable--go to WalMart and see if they have the hth 6-way drop kit, or if they don't, then at least get the cheapie OTO kit (uses red and yellow drops for pH and chlorine). You can use that to measure chlorine for now and at least keep the pool safe until you get the water balanced and some CYA in it. After the sun is off the pool, and the swimmers are out, measure your chlorine again, and add enough to get back up over 3 ppm (again, if you'll tell me pool volume, I can help you with amounts). You'll need to do the same a few times during the day, at least until you get some CYA in the pool.
    If your pH is high, and CYA is low, then using dichlor for chlorination is ideal for your pool. If you have a Sam's nearby, look for the PoolBrand dichlor chlorine (it's a powder). If not, Amazon carries a Kemtek dichlor that is also good. Don't buy dichlor from other sources, because a lot of them recently have changed formulas and are adding "goop" to it that makes it react unpredictably in pools. I would use the dichlor in your pool until your CYA gets to around 40-50 ppm, then switch to plain bleach for chlorination.
    In the meantime, log out of the forum, go to the main forum page, under the second section of the forum--the first set of threads is called "Pool chemistry for Intex pools", and once you open that, the second sticky is called "super simple pool chemistry recipe......". Read through that, and it should help you understand better what you're doing. if you have further questions, feel free to come back and post them here.
    Welcome to the forum!
    Jul 2012
    Texas
    Thanks for answering Aylad, my pool is 18ft wide 48 inches deep. Did u mean I can use regular bleach from like Walmart???
    Yes, PLAIN 6% household bleach.
    In your pool, a dose for a pool with NO chlorine and 20 people coming would be 1/2 gallon before they get there, and then 2 cups in the skimmer every hour till they leave, and then 1/2 gallon after they leave.
    I'm assuming you have no stabilizer, either.
    Jul 2012
    Texas
    That's correct, I don't have any stabilizer in it.
    Let us know if your concern extends beyond the party . . .
  1. Chlorine tabs vs chlorine bleach generic
    By Cahoonh in forum Using Chlorine and Chlorinating Chemicals
    Last Post: 06-13-2013, 10:28 AM
  2. High Chlorine Level with no Chlorine Added in 6 weeks
    By morechoff in forum Pool Chemicals & Pool Water Problems
    Last Post: 06-27-2006, 08:52 AM
  3. Free Chlorine vs. Total Chlorine adjusting
    By Truckman in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 06-08-2006, 06:00 PM
  4. alternatives to chlorine/non-chlorine pool maint
    By leewest in forum Dealing with Stains & Metals, . . . and 'Minerals' & 'Ions',
    Last Post: 04-04-2006, 11:53 PM
