Thread: Pump to filter ratio
    Jun 2011
    Wisconsin
    Default Pump to filter ratio
    Does anyone have thoughts on size of sand filter in relation to gallons? I just ordered a new filter, and replaced with same size I was using, although the specs say I need a larger one. I have a 1.5 hp pump and a 16 inch filter( 100 lbs sand) and my pool runs right around 20,000 gallons. It did fine for 10 years but recently sprung a huge leak. I appreciate anyone's thoughts on this.
    16'x32' oval 20K gal AG pool; Liquid Bleach; Hayward pro series, 18 inch sand filter; Hayward Pro series 1.5 hp pump; 15 - 20hrs; Taylor, k2006; well; summer: ; winter: ; android phone; PF:6
    Jun 2011
    Wisconsin
    Default Re: Pump to filter ratio
    Hi Watermom,
    I sent the 16 inch back and went with the 18 inch sand filter by Hayward, 150 pounds sand. Do you think this is a better match with my pump? In reading threads I guess over powered pumps are common. It was the system that came with my pool set up, but when I replace the pump, should I go with a 1 hp pump instead? Thaks for your help and stellar advice, I do appreciate you!
    I still think that pump will overpower that filter, but some of the equipment guys should be by here shortly that can better answer that question.
    I have approx. 25K gallons in my pool, and have a 1 hp pump with a 300# sand filter that works very well in my pool. I would think a 1 hp pump would be more than enough for yours.
    Quote Originally Posted by mrs.rainbow View Post
    I always try to avoid arguing with success.
    If you operated successfully for 10 years with a 16" filter, and now have the same pump, but with an 18" filter . . . it should work better than it did before. And, since it worked to your satisfaction before, it should be fine now.
  1. Is it possible to run Intex SWCG pump and filter unit with pump disabled?
    By jtran69 in forum Intex-type Pool Setup & Operations
    Last Post: 08-19-2012, 10:15 AM
  2. need new filter, may have a pump
    By illinipdx in forum Pool Equipment & Operations
    Last Post: 07-06-2008, 06:15 PM
  3. Is my pump too big for my filter?
    By AndieP in forum Pool Equipment & Operations
    Last Post: 07-06-2006, 01:29 AM
  4. Anyone else run their pump/filter 24/7?
    By Rangeball in forum Pool Equipment & Operations
    Last Post: 05-31-2006, 01:34 PM
  5. Anyone know where to buy Filter/pump combo with 2 speed pump?
    By poolbuoy in forum Above-Ground Pool Construction & Repair
    Last Post: 05-13-2006, 09:25 PM
