Results 1 to 8 of 8
Thread: pH near 8 and possibly rising
    Jun 2012
    New York
    Default pH near 8 and possibly rising
    Hello:
    I've switched to the BBB method described in this forum. I've stopped using any chlorine tablets (trichlor) thru the feeder for 2 weeks now and have seen my pH drift up to near 8.
    Cl 4
    Total Cl 4
    pH 8
    Alkalinity 160
    CYA 60
    Calcium ~ 180
    Should I be concerned that the pH is drifting up in the past 3 weeks since d/c the tablets? Before doing the BBB, I used to have to add pH up weekly to keep the pH between 7.2 and 7.8
    Pool is 8800 gallons Fiberglass
    Age of Pool is 1 year
    I realize that pools have their own personality. I never thought that I may have to add acid to my pool.
    Thank you
    Default Re: pH near 8 and possibly rising
    You were adding acid before, in the form of tri-chlor(o-isocyanuric acid). When you stopped, you needed to replace it. There's nothing unusual about that.
    Jun 2012
    New York
    Ok understood.
    So its either acid or trichlor tabs keeping the CYA level in the back of mind and in check?
    I think so -- I'm not completely sure I take your meaning.
    But all forms of chlorine have side effects:
    • Bleach has the fewest, and only adds chlorine & salt.
    • Dichlor adds chlorine, stabilizer, and lowers the pH.
    • Trichlor adds chlorine, some stabilizer, and lowers the pH quite a bit.
    • Calcium hypochlorite adds chlorine, alkalinity, calcium, and raises the pH some.
    • Salt water chlorine generation adds chlorine and raises the pH some.
    These side effects may be good, bad, or indifferent.
    For example, if you fill a pool with high pH / high TA water, dichlor's effects are ALL good: you shock the pool to get levels up, and the CYA also goes up, and the pH also goes done! But, if you use dichlor in a California pool with water that tends to be acid and is already high in CYA . . . then the side-effects are all bad.
    So, for dichlor, trichlor, & cal hypo . . . we can't answer the question, "Is this good for my pool?" without knowing quite a lot about your pool. And, since one of the critical bits of info is CYA level -- at which 'guess-strips' are particularly bad -- we constantly end up whining about, "Please get a good test kit!"
    We usually recommend bleach in unknown situations precisely because we often don't know enough about the pool to match side-effects and needs. (We also recommend it because it's almost always unavailable in un-gooped-up form!)
    Jun 2012
    New York
    Thanks for the replies.
    Note re-edit of my earlier reply above. -ben
