Re: high pH and TA, cloudy water
Acid isn't the only thing that will cure cloudy water--and with a CYA of 50, a Cl of 1-3 isn't nearly enough to keep algae from growing in the pool. I would shock the pool to 15-18 ppm, using bleach, and hold it there until you can go from sundown to sunup without losing more than 1 ppm of chlorine. I'm betting your cloudy water is an algae bloom, not a pH issue.....
