Originally Posted by Watermom (I have a 27ft AG pool with 54" walls and have a 1/2 hp inground pump and a 300 lb. sand filter.) Just curious - what benefits do you get from using an in-ground pump?
If you can post links to the exact pump and filter you have, I'll try to take a look.
PoolDoc / Ben Get the testkits you needBest Guess Chlorine Chart* PoolForum Amazon store *Edit your signatureSubscribe to the ForumBBB Method of Pool CareFixing Cloudy Pool WaterUsing muriatic acid to lower your pH SS Recipe PoolSolutions GuidesSearch PoolForum, PoolSolutions, and other pool websites.
