Results 1 to 9 of 9
Thread: Can I slope floor Intex 16' ultra deeper towards center?
    Default Re: Can I slope floor Intex 16' ultra deeper towards center?
    This question produced a little bit of controversy, so I check things out myself, using the caternary curve calculator, here:
    http://www.spaceagecontrol.com/calcc...tton=Calculate
    The actual curve will depend on how carefully you grade things, but if you grade them evenly, it should approach, at such a small displacement, a caternary curve very closely.
    At the 4" dishing Dave suggested, the ∆length (change in the diameter of the pool) is only 1/4 of an inch. I don't think that would have any detectible effect on the pool.
    Even at 8" -- double what Dave suggested -- the ∆ length is 0.07ft, or 3/4in. And, with an Intex metal frame or blow-up pool, I suspect you won't be able detect a 3/4" ∆ in the diameter of the pool at the top compared to the bottom.
    But you have to be careful. It's possible that if you dish the pool 12", you might get a bit of wrinkling, depending on how elastic the Intex fabric is. At a 12" dish, you'd increase ∆length (diameter) by 2"; that might be a problem, especially if the fabric is very inelastic.
    Jul 2012
    New York State, USA
    I'm no expert on these things but I'm thinking about the physics of what's going on here. If you "dish" the bottom of the pool, you're effectively placing lateral stress on the bottom of the liner, from the edges towards the center. That extra stress is going to tug on the seam between the sides and bottom, which could cause the seam to catastrophically fail.
    If you were planning on replacing the pool in the next 12 months anyway, then maybe the risk is worth it if your pool is sited in a location where a sudden flood won't cause any damage. Me, I've got neighbors with landscaping right on the other side of the fence so I can't take those risks
    14 round 3.8K gal Intex AG pool; SWCG; Intex Krystal Clear model 56637E 1,000 gph Filter Pump cartridge filter; 8+ hrs; HTH 3-way test kit (drops) for Chlorine and pH; Intex "guess strips" for TA; utility water; android phone; PF:31
    Quote Originally Posted by IGnatius T Foobar View Post
    Only if the stress causes the material to exceed the elastic limit -- something that's pretty unlikely in a PVC fabric strained by only 1/4" over 16'. Also, because the dishing will occur prior to filling, any tension that does approach the elastic limit will be more likely to simply slide the fabric in toward the center. This could cause the wrinkling I mentioned, but not necessarily put a great deal of tension on the seams.
