Thread: Green water!
    Jul 2012
    Texas
    Unhappy Green water!
    I recently put up a 22ft x 52inch round above ground pool. I chose to go with a saltwater system and a sand filter pump. I read my booklet that came with the saltwater system as to how much salt and how long to run the system after putting in the salt (5 -40lb bags) and running the sand filter 24 hours. My size pool was not in the book!! So I guessed and I was wrong? My pool turned green two days after running the system for only four hours. I have added a bag of shock it. Boosted the system and ran it another 7 hours after boost ended. Went home for lunch today, it isn't as green as it was. How long should I expect to wait for the green to go away? Also, at this point can I turn off the system and add bleach? Leaving the sand pump running. I run this 24/7 anyway. Help???? I just want sparkling clean water!!!!
    Default Re: Green water!
    If you run the SWCG for only 4 hours daily, and don't have any stabilizer in the water to protect it from the sun, you're basically going without chlorine for 19 or so hours of the day, which is why your pool turned green. Generally, we recommend that people get their water balanced without the SWCG, and then turn the SWCG on for maintenance. It can't generate enough chlorine fast enough to "shock" the pool to clear up an algae bloom, so all you're doing is wasting cell life by using an SWCG on a green pool.
    So...if your pool is 22 ft diameter, assuming a 48" water depth, I'm calculating 11,400 gallons. In that much water, each gallon of 6% bleach you add will raise your FC by 5.3 ppm. Assuming no stabilizer, you need to add enough bleach to get your FC up to 12-15 ppm, and then hold it there until the pool clears by testing your water and adding more bleach as often as you can, but at least 2-3 times daily. To do this, you need a way to test the water without depending on the pool store to do it for you. Do yourself a favor and order a good kit (we strongly recommend the K-2006 you can find in the link in my sig). Until then, check your WalMart and see if they have any more of the hth 6-way drop kits. At a minimum, at least pick up one of the cheapie OTO kits (uses red and yellow drops for pH and Cl) and test your water with that.
    Leave the SWCG off during the process, get the pool shocked, run a set of test results on your water and post them here, and we can help you go from there! An algae bloom isn't that hard to clear up, but the longer you put it off, the more bleach and time it will take.
    Welcome to the forum!
  1. light green water due to metal in my well water
    By marios in forum Dealing with Stains & Metals, . . . and 'Minerals' & 'Ions',
    Last Post: 06-17-2013, 08:48 PM
  2. Replies: 8
    Last Post: 08-04-2012, 11:43 PM
  3. green water or green liner?
    By denanbob in forum Dealing with Algae & Slime
    Last Post: 05-26-2011, 12:16 PM
  4. green water that won't go away
    By kinneydd in forum Dealing with Algae & Slime
    Last Post: 06-30-2006, 09:40 PM
