I recently put up a 22ft x 52inch round above ground pool. I chose to go with a saltwater system and a sand filter pump. I read my booklet that came with the saltwater system as to how much salt and how long to run the system after putting in the salt (5 -40lb bags) and running the sand filter 24 hours. My size pool was not in the book!! So I guessed and I was wrong? My pool turned green two days after running the system for only four hours. I have added a bag of shock it. Boosted the system and ran it another 7 hours after boost ended. Went home for lunch today, it isn't as green as it was. How long should I expect to wait for the green to go away? Also, at this point can I turn off the system and add bleach? Leaving the sand pump running. I run this 24/7 anyway. Help???? I just want sparkling clean water!!!!
