Results 1 to 10 of 11
Thread: High Phosphates
    Default Re: High Phosphates
    With a zero chlorine, you need to get bleach in it today--NOW!
    If the water is green, go ahead and shock the pool per Watermom's instructions. You'll need to test as often as you can during the day, and add whatever amount of bleach you need to get back up to the shock level. The more consistent you are about keeping it at that high level, the quicker the pool will clear.
    The reference to sundown that Watermom made was for testing, after the pool has cleared, to make sure all the algae is gone. If you test one night and again the next morning without having added any more chlorine to the pool, and don't lose any in that time, then you're finished shocking and can let the chlorine drift back down. But while you still have green water, you just need to test as often as possible and focus on maintaining that shock level of 20 ppm.
    Jul 2012
    Connecticut
    That's the thing, the water is crystal clear
    It may be clear now, but if you let your chlorine drop to 0 with a CYA reading of 60, then you probably have something starting in there that hasn't "bloomed" yet. My advice is the same. Go ahead and shock the pool. It may be that doing so one time will be all that you need and you'll find that you don't lose more than 1ppm of chlorine overnight. If that is the case, then you'll be good to go as long as you don't let the chlorine drop again. But, my opinion is that it is better to go ahead and shock a pool that looks clear rather than chance it and end up with a green pool.
    Jul 2012
    Connecticut
    Can I assume it isn't safe to go in the pool until I'm done with this process and am able to let the chlorine drop to normal levels?
    I wouldn't have a problem with going in the pool, but you don't want to wear brand new suits while the pool is at shock level. As long as the water is clear and there is "some" chlorine in the pool, I wouldn't have a problem swimming in it.
