Page 3 of 3 FirstFirst 1 2 3
Results 21 to 22 of 22
Thread: Salutations
  1. #21
    Jul 2012
    michigan
    Default Re: Salutations
    Its not perfect but I can see the bottom of the pool for the first time in a long time. At this time the only thing I'm adding to the pool is bleach. I'm just having difficulty keeping the chlorine levels up. I'm thinking this is caused by a number of factors, including algae, heat & lack of CYA. I really wish it was the weekend so I could allot more time to it but I'm going to keep on keeping on.
  2. #22
    Try and add enough bleach in the morning before you go to work to get it back to shock level. Then, check it when you get home and add enough to get back to shock level and then do the same as late in the evening as you can before you got to bed. The more often you can shock it and the more consistently you can maintain that high level, the faster you'll get past this.
    Glad there is some progress.
