Interesting. Those aren't exactly the colors I would have expected.
Do the colors in the photo accurately reflect what you saw? I would have expected a more red color.
Did you do anything different than what's in the metal bucket test instructions?
The colors are close. No, I followed directions: used 4 gal. fill water, added 1/2 cup bleach, mixed and after 15 min. added 1/2 cup borax, mixed, covered and checked in 24 hrs.
Should I do the lime bucket test on fill or pool water?
Thanks.
After two 1/4 gal doses of bleach, the water is much clearer. There's light rust colored sediment on the pool floor. The chlorine level was 5 ppm, too high for swimming today. The skimmer and vac I ordered should be here end of the week.
5 ppm is *NOT* too high to swim; that's bogus stuff that traces back to standards that were established in the '60's, on a purely 'pulled that one out of the air' basis. During the *same* time when "above 3 ppm" was set as "too high to swim", there was NO upper limit on chlorine in drinking water. Some utilities routinely shipped drinking water at 10+ ppm, so there would still be chlorine in the water when it reached the end of their old and corroded water lines!
However, if you still have no CYA, that chlorine will drop by over 1/2 in an hour of full sun!
Read the Best Guess page, linked in my signature, to get a better understanding of this.
PoolDoc / Ben
Got it, Ben. Thanks for the info. I'm waiting for your direction on next steps with the cloudy pool. HEDP was ordered and vac & skimmer are on the way. I have muruatic acid and polyquat on hand.
If you would, go ahead and complete the pool chart:Pool Chart Entry FormI know you did the metal bucket test; but have you done the lime softening test? If we do that, and every settles out nicely, that process will ALSO remove all the metals remaining in the water.
Chart complete, lime test underway.
15' round 5K gal Intex AG vinyl pool; 6% bleach or hth chlorine granules; Intex 637 cartridge filter; Intex 637 pump; 24hrs; Hth 6-way drops; well; summer: solar; winter: Will store away; iPad; PF:24
