Results 1 to 10 of 17
Thread: Help treating water in childs pool
    Jul 2012
    Maryland
    Default Help treating water in childs pool
    I just bought an 8'x30" pool to get the 5 and 7 year old grand kids to get them through the last month of their summer vacation.
    I just completed setup yesterday filling it with the hose. I found this site to help me understand the water treatment, but never having a pool before I'm not sure where to begin. I purchased HTH 1" chlorinating tablets for bow up pools, ph minus because ph reads 7.8, and algecide.
    Not sure where to begin. Tthe pool only holds 650 gallons of water. Chlorinating tablets said to use 4 per 10,000 gallons so I just put 1/4 of a tablet in the floating skimmer to give it some chlorine. I'm wondering if I should have used the HTH stabilizer first but I wasn't sure and that was one chemical I had not bought. Since I can't even get it until tomorrow and the chlorine gage did not even register I figured I should at least give it a little chlorine until I can go to the store tomorrow.
    Can someone help me with the order to apply chemicals and how far apart to do them. I appreciate any help or advise. Thanks
    Default Re: Help treating water in childs pool
    Hi, Chris, and welcome to the Pool Forum! There is a thread that would probably be helpful to you but until your registration is complete, you'll need to log out to be able to read it. From the homepage, go to the sub-forum called Pool Chemistry for Intex-Type Pools. There is a thread called "Super Simple Recipe for Intex pools" or something similar. Read that and then come back here if you have further questions.
    I would also like to ask you to put your pool's information in our pool chart. It helps us to be able to better advise you in regards to your pool.
    Pool Chart Entry Form
    What type of test kit do you have? What are the ingredients of your chlorinating tabs? Anything in them besides trichlor?
    Lehigh Valley, PA
    I used to have a very small pool like this when my kids were little. I can steal hear their squeals of delight when they and their friends played in it, great memories!
    All I ever did was to add 1/4 cup of bleach in the evenings and swished it around with a soft household broom. The pool didn't have a filter or a pump. When the water got muddy from little feet I dumped it and refilled it with the hose. The sun heated it up very quickly.
    Jul 2012
    Maryland
    Thanks, I have read the Super Simple recipe for Intex Pools. My ph is ok but I cannot get the bleach to even register. I filled the pool Saturday and we have had very little sun until today. Last night I put 1/4th of a HTH 1" chlorinating tablet in a floating skimmer (active ingredient 92.4% Trichloro-s-Traizinetrione, available chlorine 84%, purchased at Walmart). This morning it was still in there, I had thought it would dissolve.
    Then I read this post so I removed the skimmer and tried the generic bleach. I kept adding periodic amounts of 1/8th cup and testing about 1/2 hour later, it did not register so I added 1/2 cup. If it registered at all it was so slight I wasn't even sure there was a yellow tinge. At 9pm this evening I put 6 oz of bleach and stirred water up, filter has been running since about 4pm. Can I add too much bleach? If I do will it lower itself just sitting in sun with no swimmers?
    I have purchased but not used the borax and the recommended algaecide.
    I realize this is just a cheap pool set up but I just wanted something for the grand kids to enjoy the last 4-6 weeks of hot weather, I'll be happy if it lasts that long, I just need to make sure I am doing the chemicals right. I'm sorry I did not come to this forum before I bought and filled!
    As long as you stay with 1 cup or less at a time of bleach, you won't be adding too much...but without stabilizer in the water, whatever you add will be gone in less than an hour's time, which is why you put in a reasonable dose (1/2 cup) but it wasn't there when you re-tested.You're right that the sun will degrade whatever bleach you put in, so you actually could put in 1-2 cups at a time (2 cups would take your FC to 12 ppm temporarily), and the sun would burn it down pretty quickly. I would probably put in 1 cup, stir it around, let them swim, then follow that with another cup after they got out.
    Keeping the trichlor pucks in the pool will help--just don't let the kids play with it and I would remove it from the pool while they're swimming. It can take a few days for the pucks to dissolve--they don't normally dissolve in just one day's time.
    Jul 2012
    Maryland
    Thank you! Would you use both bleach and floating tablet at the same time? As long as ph stays OK is that all I need to do?
    You can do both at the same time but just do NOT pour the bleach near the tab and you'll be fine. Many people do use both. Just make sure that your trichlor tabs do NOT have any copper in them.
    Jul 2012
    Maryland
    How do you know if there is copper? It is not listed in ingredients but all is says is active ingredient 92.4% Trichloro-s-Traizinetrione and the other percentage just says other ingredients.
    If there were copper in them, you would see it listed on the ingredient list as "copper pentahydrate" or something of that nature.
    Lehigh Valley, PA
    Copper is not always required to be listed as an ingredient, depending on how much or how little is in the product. Per the MSDS the ingredients for HTH Dual Action 3" chlorinating tables are:
    TRICHLORO-S-TRIAZINETRIONE 90 - 96 %
    Copper Sulfate pentahydrate 1.4 - 1.55 %
    Aluminum sulfate 4.5 - 4.9 %
  1. Chlorine Pool Water seems like salt water?
    By heatherc in forum Using Chlorine and Chlorinating Chemicals
    Last Post: 08-08-2012, 05:04 PM
  2. Help with identifying and treating brown stain
    By Beakman in forum Dealing with Stains & Metals, . . . and 'Minerals' & 'Ions',
    Last Post: 07-11-2012, 12:42 AM
  3. Treating my new ppol
    By poolnewbee in forum Pool Chemistry for Intex-type Pools
    Last Post: 06-10-2012, 09:34 PM
  4. Salt Water Pool Water Smells Like Must
    By desherer in forum Salt Generators (SWCG) & other Chlorine Feeders
    Last Post: 06-28-2011, 02:20 PM
  5. got new 24x5 round intex pool need help with water. Sandy water..help
    By iwannaswim in forum Pool Chemistry for Intex-type Pools
    Last Post: 06-08-2011, 09:42 PM
