Thread: Baquacil to Chlorine help
    Jul 2012
    WV
    Default Baquacil to Chlorine help
    I've been using Baq since I purchased our pool several years ago and am tired of fighting it. CLOUDY, SNOTTY, ALGAE AND COST. Can someone explain the transition to chlorine. Neighbor has and inground pool and uses simple clorox and its beautiful and without problems. By the way ours is an above ground 18X34.
    Default Re: Baquacil to Chlorine help
    From the forum's homepage, go to the section called PHMB:Baquacil, Softswim, Clear Comfort, Etc. The top thread in it is a FAQ that explains the process. Until your registration is completed, you will have to log out first to be able to see the other sections of the forum.
    Welcome to the Pool Forum!
    membership upgraded. -ben
    here's the Baquacil info: http://www.poolforum.com/pf2/showthread.php?179
  1. Baquacil to Chlorine conversion
    By telesforos in forum Chlorine Alternatives: UV, Ozone, Baquacil (PHMB), etc
    Last Post: 06-16-2012, 08:51 PM
  2. Baquacil Conversion to Chlorine
    By texashornsbys in forum Chlorine Alternatives: UV, Ozone, Baquacil (PHMB), etc
    Last Post: 07-25-2006, 11:42 PM
  3. Converting from Baquacil to Chlorine
    By tammydiaz in forum Chlorine Alternatives: UV, Ozone, Baquacil (PHMB), etc
    Last Post: 07-05-2006, 11:46 PM
  4. Converting Baquacil to Chlorine
    By tgilbert in forum Chlorine Alternatives: UV, Ozone, Baquacil (PHMB), etc
    Last Post: 06-19-2006, 04:08 PM
  5. New - Need your help w/my baquacil to chlorine conversion
    By dacslow in forum Chlorine Alternatives: UV, Ozone, Baquacil (PHMB), etc
    Last Post: 05-29-2006, 03:53 PM
