Results 1 to 9 of 9
Thread: Pool Pump Valves (or lack thereof)
    BigDave's Avatar
    Default Re: To the Mod - Did I do something incorrectly?
    As AnnaK points out isolation valves (shut the pool water off from the equipment) make regular maintainance much eaisier especially when the equipment is below the waterline. I believe (and I open to correction) that if you want to throttle the flow through your system the best place for the throttling valve is on the pressure side of the pump before the filter.
    Jul 2012
    Ontario, Canada
    Default Re: Pool Pump Valves (or lack thereof)
    Thanks guys.
    I want to have my pool closed professionally for me this year (and opened in the spring) - just so I can observe and learn how to do it correctly. I think I'll ask the service guys about adding an isolation valve - sounds like I should really have one.
    Cheers.
    Quote Originally Posted by Cdnpoolnewb View Post
    An excellent idea (one I've recommended often ), and so is asking them about the valve!
