Siphon? Shop vac? Small sump pump?
Thanks, Ben.
The metal had stained the bottom of the spa. I realize now, that my entire system was out of whack... hence the ' Yuck' spa... i.e., algae stains... yellow, green, and some black. So I am in the process of getting things back up to "balance". Did soak stain overnight with 'tri-chlor in wet sock' ... helped. Scrubbed more today.. Sump Pumped out extra water. Now refilling. It is looking much better.
Question: Do you have any recommendations for a SWCG tester? Can't seem to get into the other boards right now to read up on current info.
Thanks again,
Karin
What do you mean, an SWCG tester? For salinity levels?
If so, yes: the Aquachek strips (the ONLY Aquachek product we recommend!). There are pictures and links on the test kit info page; and there's a link to that page in my signature.
PoolDoc / Ben
Hi
wondering why my account is disabled?
Karin
18'x36' L' 26K gal IG pool; SWCG; Pentair Clean & Clear Plus cartridge filter; Pentair Intelliflo VS 3050 pump; 8hrs; Ordering a SWCG tester. Have been testing at Pool Store; or using reg. red/yellow drops left from prior cholorine use. ; utility water; summer: ; winter: ; iPad; PF:4.6
It's enabled now.
PoolDoc / Ben
