Results 1 to 9 of 9
Thread: SWCG and Unplugging the Copper Ionizer
    Jun 2012
    Michigan
    Default SWCG and Unplugging the Copper Ionizer
    Hi,
    I just wanted to know if I should plug the ionizer back in after use of the SWCG as to keep it dry. It has a cpl prongs that fit into the cap I pulled off and I'm not sure if they need to stay dry since the cap is such a heavy gauge rubber and there's a fitting around it to keep it tightly sealed. I'm assuming it's to keep it dry?
    Just finished filling a bit ago and added the salt etc. Running the SWCG now and will get my first readings in the morning.
    Can't wait to take a dip tomorrow! ~;o)
    15' x 48" round 4.4K gal Intex AG pool; Unicel Type C-5315 cartridge filter; Intex 633T pump; (24/7) Taylor 2006 kit; utility water; summer: ; winter: ; iPhone; PF:27
    Jun 2012
    Michigan
    Exclamation Re: SWCG and Unplugging the Copper Ionizer
    Hello anybody out there, anybody?
    My posts seem to get lost in the cracks somehow. Hoping someone see's this thread and can give me a hand here. There have been views, but no replies.
    Jun 2012
    Michigan
    Readings for Yesterday (Tuesday)
    CL .5
    PH 7.2
    That was after running SWCG for 3 hours and filter for 4 hours.
    My pool is in full sun most of the day. My "son" swam yesterday most of the afternoon. Evening readings to follow:
    CL 0 (possibly .5, I'm colored blind and these yellows are so hard to read)
    PH 7.5
    Ran filter all night
    This morning's readings:
    Cl 0-.5
    PH 7.2
    CYA 30 (Is the dot suppose to totally disappear, mine turned gray but not totally gone)
    TA 70 (more of a pink/red-added an extra drop seemed a tad bit redder) Damn colored blindness!
    TH 120
    I now have the SWCG running for 4 hours to try and produce more chlorine.
    Also I have noticed some people testing FC, what is that?
    So, whatcha think bout my numbers?
    BigDave's Avatar
    Default Re: SWCG and Unplugging the Copper Ionizer
    I think you need more chlorine. SWCGs can be great for maintaining chlorine in your pool but are not very goot at bringing it up. I'd put 5 or 6 Cups of plain 6% household bleach (no fancy scented splashless or outdoor - just plain bleach - 6%) and do it quick before your pool turns green.
    The FAS-DPD test that in the K-2006 separately measures Free Chlorine (FC-kills germs and algae) and Combined Chlorine (CC-indicates FC is engaged in oxidising stuff in the pool).
    If you haven't yet ordered a K-2006, you should. It should be especially helpful as there's no shades of yellow to distinguish - sample turns pink if chlorine is present - add drops until sample turns clear, should be easier to read for you.
    Jun 2012
    Michigan
    I will def add the bleach tonight, especially after having 5 ppl in the ppl this afternoon. After running the SWCG for 4 hours earlier in the afternoon my chlorine came up to 1. I'd still like it a bit higher than that thou. Plus I am going to have to add more water because of splash out so I'm sure the bleach will help.
    I have also ordered the kit, just waiting on it. So glad to hear I don't have to try and distinguish yellows anymore! lol
    Another thing, Where are we suppose to dump the test waters when were threw with them? Is it ok to just fling it in the yard or do I need to worry about it harming the grass or worse yet possibly effecting my dog?
    Any thoughts on the the original post regarding covering the copper ionizer when not in use?
    Thanks for the advice, much appreciated.
    I can't answer the question about the copper ionizer, sorry. But about disposing of testing water, I always just just dump it in the yard. So far, none of my dogs has grown three heads!
    Jun 2012
    Michigan
    LOL That's good to know Watermom!
    Jun 2012
    NE Nevada
    First off, I want to make it clear that I am a complete pool rookie!
    And I may be out of line responding... But I did install an Intex 15' X 48" pool with Intex 1600 gpm pump and SWCG in June. I never plugged in the copper ionizer and have just left the connections hanging. I have had no issues with this.
    And thanks to this forum and the K-2006 test kit my water has been perfect!
    15' round 4.4K gal AG vinyl pool; SWCG; Intex 15'x48" metal frame sand filter; Intex sand and SWCG 1600gph pump; don't know yethrs; I will be using K-2006 and aquachek salt strips; utility water; summer: solar; winter: none, yet; ; PF:27
    Quote Originally Posted by rmk_racer View Post
    Intex staff told me that it was fine to do this, though it wouldn't be a bad idea to use some Scotch 33+ electrical tape to cover up the connections.
  1. Intex's mongrel SWCG + Copper sanitation unit
    By PoolDoc in forum Salt Generators (SWCG) & other Chlorine Feeders
    Last Post: 06-10-2011, 01:54 PM
  2. Liquid Ionizer/copper
    By drako4 in forum Pool Chemicals & Pool Water Problems
    Last Post: 07-02-2010, 08:34 PM
  3. What should I do with the Copper Ionizer?
    By lora13 in forum Pool Chemicals & Pool Water Problems
    Last Post: 05-07-2006, 12:37 AM
