Thread: First time testing water....can this be right???
    Jul 2012
    Illinois
    Default First time testing water....can this be right???
    The brand new pool finished filling up Monday night. Finally got electric out to the pump last night. It has an automatic chlorinator/mineral pack that uses trichlor tabs. In the couple days the pump wasn't running, the sides and bottom were beginning to get slick and greenish. So when the pump started up, I added 2 gallons of bleach last night. I tested the water this morning and this is what I came up with:
    FC 3.2
    CC 0
    TA 250ppm
    pH 7.6
    What is up with the TA? My Taylor kit says the ideal range is 80-120, but the charts only go up to lowering it by 100ppm by adding 2 gal muriatic acid. This seems extreme, so I wanted to check in before doing anything!
    Thanks!
    Lee
    Just moved in so I'm not exactly sure on manufacturers or specs; best guess: 24' x 48" AGP, sand filter with 3/4HP pump, Taylor K-2006
    Jul 2012
    Illinois
    Default Re: First time testing water....can this be right???
    Forgot the CYA....the solution was not cloudy at all, so the black dot never "went away". Does that mean no CYA or too much? Haven't added any stabilizers (that I know of, other than the trichlor tabs).... Sorry, brand new at this, but I have been trying to read up on here!
    It sounds like dichlor would be the best product for you, right now: it lowers the pH, adds stabilizer AND chlorinates. Later, you won't need those things, and it will be a poor choice, but right now, it may be the best. Links below.
    Regarding high TA . . . it is NOT an urgent issue, unless you have a heater or are having some scaling. But here's a page that explains more:
    http://www.poolsolutions.com/gd/lowe...p-by-step.html
    Also, read the muriatic acid page linked in my signature, and then use MA to keep your pH below 7.6.
    Finally, since you didn't report calcium levels, I'm guessing you may not have a recommended kit. Links for those below, too.
    Good luck!
    Ben
    24 lbs PoolBrand bagged shock @ Sams Club
    Kem-Tek Dichlor 22 lbs @ Amazon
    + Here are links to the kits we recommend:
    HTH 6-Way Test Kit @ Walmart
    Taylor K2006A (3/4 oz bottles) @ Amazon
    Taylor K2006C (2 oz bottles) @ Amazon
  1. Testing water for first time this year
    By Digger in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 06-20-2012, 02:42 PM
  2. First time testing: Not sure of Chlorine #s
    By drako4 in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 06-30-2010, 05:50 PM
  3. First time testing - check me please
    By btozzo in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 06-27-2010, 11:39 AM
  4. 3rd year with pool, 1st time testing it right.. Please advise
    By fishandfly in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 05-03-2008, 11:06 AM
  5. Testing Time
    By mohawk in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 08-09-2006, 11:23 AM
