Thread: bleach or granular shock?
    Jul 2012
    michigan
    Default bleach or granular shock?
    I have a question......Do you recommend using Bleach instead of granular shock.
    Default Re: bleach or granular shock?
    Either will work, but PLAIN 6% (ck %) bleach has fewer 'side effects' and is MUCH more likely to be just chlorine with no goop.
    Granular "shock" materials are very hard to purchase these days, since most pool chemical companies are diluting and blending them with goop you don't want in your pool; you pretty much have to be an expert "Label Inspector" to buy that stuff safely.
  1. 6% household bleach equivalent to lithium hypochoride granular?
    By magnus in forum Using Chlorine and Chlorinating Chemicals
    Last Post: 05-24-2013, 10:51 AM
  2. Calcium Hypochlorite Granular Chlorine vs Bleach
    By herb396 in forum Using Chlorine and Chlorinating Chemicals
    Last Post: 07-08-2011, 03:24 AM
  3. Can't get bleach. shock-it ?
    By jimmyzshack in forum Dealing with Algae & Slime
    Last Post: 05-29-2008, 07:55 PM
  4. Shock with Bleach
    By Pool in Carolina Blue in forum Using Chlorine and Chlorinating Chemicals
    Last Post: 08-26-2006, 03:15 PM
  5. Shock vs Bleach
    By ksturge in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 05-24-2006, 08:05 PM
