Results 1 to 10 of 15
Thread: Newbie who lacks pool smarts needs those who have The Smarts
    Jul 2012
    Phoenix, AZ
    Default Re: Newbie who lacks pool smarts needs those who have The Smarts
    Thanks so much for your help, I really appreciate it. I will follow your advice above, as well as order the Taylor.
    Oddly, I filled out that pool forum right after I registered - I wonder why it's not there. Do I have to enable something for it to show?
    I looked at your chart . . . and something is seriously wrong.
    You list your pool as freeform, with a max length of 48 feet and a max width of 36 feet, with a depth ranging from 3 - 5 feet, and then list your gallons as 11,000. But a 36'x48' rectangle 3' deep (no 5') would be more than 38,000 gallons! Granted, your pool may have some narrow 'waisted' sections, but to be 36x48 and have only 11,000 gallons, it would have to be shaped like a doubled headed snake, 48' long, with the heads separated by 30'!
    You probably need to re-measure AND send pictures to [email protected]
    Never mind -- you gave your address when you registered, and Google seems to have pictures of your pool. Your pool is closer to 20 x 20 than it is to 36 x 48:
    11,000 gallons is probably a reasonable estimate. I cropped the photo so your location can't be guessed from the photo.
    Jul 2012
    Phoenix, AZ
    Yup, that's my pool! My 20x20, 38,000 gal pool . Oops. I measured last night using the 'step it off' method, except it's quite clear that I didn't understand it; when I entered last night's numbers, I thought wth? bc I knew they seemed bizarre. Thanks so much for helping me out on it. My poor, poor pool is in challenged hands.
    Anyway....I followed Watermom's advice and added 5 gal of 6% last night....which I thought might bring me up to the 25ppm suggested. Here are this morning's numbers:
    --chl: 7ppm
    --alk: 180
    --pH: 7.6
    --cya: 150
    --no visible signs of any algae; water clear
    I'm really confused as to why it only went up to 7ppm, after 5gal...any advice on what I might try next? Should I use actual Shock powder this time, would that be easier until I get it to a better place? For longer term, how will I get that cya down permanently so that the chlorine is better managed? I may be asking all the wrong questions, but I sure hope to learn.
    Thanks again!
    20'x20' free-form 11K gal IG pool; chlor tabs; Hayward Swim Clear cartridge filter; 1.5HP Hayward Northstar; 6hrs; generic drops kit; planning on the Taylor; utility water; summer: ; winter: ; none; PF:11
    13x16 free-form 11K gal IG pool; Chlor tabs/floater; filter; pump; 6hrs; Some generic thingy w/ drops - planning on the Taylor; utility water; summer: ; winter: ; none; PF:11
    High chlorine loss overnight indicates some sort of 'goo' in the water that chlorine will burn up. What sort of filter do you have? Some times the 'goo' is in the filter. If you have a cartridge or DE filter, it might be a good time to break it down and clean it completely.
    BUT . . . .keep adding 5 gallons of plain bleach each evening, and then test in the morning before the sun really is on the pool.
    Jul 2012
    Phoenix, AZ
    Hmmm...now I'm more confused. We just had our filters cleaned about 2 mths (or less) ago, so I'd be surprised if they were already bad. It's cartridge, not DE. I don't have any idea how to take apart the filter thing; I'd have to call someone for that. Do you think it's imperative, given we just had them done?
    Is it an option to shock it up to 25ppm via regular shock powder...get it stable...and then start the BBB method? I'm pretty petite and if it's likely I'll need 20 gal of bleach over the next few days, then I'm wondering if it'd be easier (for now) to just get the shock and later start BBB.
    Thoughts?
    Again, thanks for your help.
    1. Regarding the filter, post the EXACT filter make / model + pictures if at all possible, sent to [email protected] . . . and answer a question: has the pool been green and slimy since the cartridges were cleaned?
    2. Regarding shock . . . nope, that's not an option till you can tell us EXACTLY what your "shock powder" is -- EXACT manufacturer and product name -- AND can give us test readings. (Some stuff sold as 'shock' is a MESS, and regardless, we can't tell how the side effects of different materials will affect your pool, till we have test readings.)
    Have you ordered that kit?
    Ben
    Jul 2012
    Phoenix, AZ
    Thanks Ben. I've ordered the kit, but it looks like it will be a couple days. To answer your post:
    1. I just now sent the pics you requested, so hopefully they are there. And nope, pool hasn't been green and slimy at all since the cartridges were clean. That said, I think there may have been one time that it got slightly more dirty than usual, but it cleared up...can't recall if that was right before the cartridge change, or after.
    2. I don't have any shock powder on hand...so if you had one you wanted to recommend (that I could possibly pick up locally), let me know and I'll get it. When you say 'until we have test readings', do you mean like the ones I've been posting the last couple days? Or, do you mean a reading once I have a better kit?
