Re: Still no chlorine and sometimes high ph
I am still trying to learn to navigate through this forum. I filled out the Pool Chart but I don't know where it went. I have a 24ft x 52 in. above ground pool that holds 10472 gallons of water. I just put the pool up about a month ago. I also have the SWG. I opened with 5 bags of salt which later found out it wasn't quite enough so I added another bag and a half for a total of 6 1/2 bags. I only ran the SWG for 4 hours, which I also found out later that wasn't near long enough. My water turned green of course! I found this forum and was helped tremendously to get my water clear again by using bleach. My water is clear but I am having trouble keeping the chlorine level up and the ph level down. This morning I added a gallon and a half of bleach. Went to work, came home at 5, tested it with the hth 6-way from Walmart. It showed no chlorine. I added another gallon and a half. Tested again and got these readings: ALK - 240; Chl- 5; Bro-10; PH- 8.2; Hardness- 70. My SWG is off but my Intex Cartridge filter pump is running 24/7. Should I add another bottle of bleach tonight and retest in the morning?
