Re: Intex Super Simple Startup and Maint plan questions
The 'Super Simple' plan is based on dichlor -- I haven't tried to make a bleach only plan because plain stabilizer is (a) hard to dissolve and (b) becoming hard to find.
Dichlor goes VERY well with an SWCG, if you use dichlor till your CYA reaches 50 ppm, BEFORE you turn your SWCG on. If you CONTINUE to use dichlor to 'shock' (boost your chlorine to higher levels) it will (a) preserve your SWCG; (b) maintain and supplement your CYA level (needed by the SWCG) and (c) push the pH down, compensating for the upward pH tendency of SWCG's.
