The Simple Care plan* is stand-alone, and is designed for folks new to pools who aren't ready to tackle all the chemistry issues, and who may not yet have the K2006 test kit.
Using an SWCG is not really compatible. To operate an SWCG system correctly requires establishing certain chemical levels, particularly salt and stabilizer IN ADVANCE, and maintaining them.
If you are currently following the Simple plan, I'd recommend getting the test kit (and salt strips) and the learning to establish and maintain correct salt, stabilizer, pH, and calcium levels before turning on your SWCG. Following the simple plan will result in gradually increasing stabilizer levels (CYA) but you'll probably need to add stabilizer directly to get there more quickly.
*Super-simple-pool-chemistry-recipe-for-Intex-type-pools-start-up-amp-routine-care.
