Results 1 to 8 of 8
Thread: Bleach with a new liner....What to do not to make wife mad
    duraleigh Guest
    Default Re: Bleach with a new liner....What to do not to make wife mad
    Hi, Tim,
    I have used bleach the past couple of years and loved the results, though the wife noticed around the permieter of the liner it appears the liner was bleached.
    That word "perimeter" got me thinking a little. Is the fading above or below the waterline? If it's at or above the water, I would suspect you've got UV degradation (fading from the Sun) rather than bleach.
    I've never seen a bleach faded liner, so I'm pretty much guessing but it seems bleach would fade at least as much underwater. If it's exactly at the waterline, perhaps that could be a combination of the two factors. It also seems that bleach damage would be spotty or blotched (from the temporary high concentration) and not very uniform in appearance
    Lastly, I would say that dark blue is somewhat problematic for fading. Typically, darker colors are the most susceptible to color change over time.
    I have never added bleach any other way then directly into the skimmer.
    Thanks everyone. The lightening of the liner was around the perimeter at the very bottom of the pool.
    Good idea about the jets, I will do that.
    Thanks again all!
    West, Texas
    I have always poured my in at the return jets and never had a problem
    Boyd
    27' Round AG, 17,204 gallons, sand filter
    Proud Father of an Army Soldier
    Perimeter at the bottom sounds more like you dumped powdered shock into the pool that was not fully disolved and the granulars sat at the bottom along the edges.
