Thread: In-Ground Pool: Spider Gasket Replacement Hayward SP711
    Aug 2012
    Quebec
    Default Re: In-Ground Pool: Spider Gasket Replacement Hayward SP711
    I managed to contact the previous owner and he told me how he opened it. He just stop the pump and unscrew the cap of the tank where the gasket is located. Since it is an in-ground pool, the water will not go up in the tank and I was able to remove the old gasket, clean everything, put some loctite (got some on my fingers ) and reinstall the new gasket. Started the pump next morning and everything is running smooth since then.
    Thanks!
    Good deal!
  1. Need a Hayward spider gasket
    By Bkirrane in forum Pool Equipment & Operations
    Last Post: 05-28-2012, 10:30 AM
  2. Hayward spider gasket replacement
    By briel in forum Pool Equipment & Operations
    Last Post: 05-24-2012, 10:20 AM
  3. Spider Gasket
    By markphin in forum Pool Equipment & Operations
    Last Post: 05-21-2012, 01:18 PM
  4. Hayward spider gasket...uh missing?
    By scarywoody in forum Pool Equipment & Operations
    Last Post: 06-07-2007, 01:03 PM
  5. Spider Gasket for Hayward GM142
    By Wayne LaBanca in forum Pool Equipment & Operations
    Last Post: 08-06-2006, 08:26 AM
