Re: At My Wits End
PoolDoc
Your pH and TA readings will be weird with chlorine that high -- that's normal. Ignore them. (Don't test them! -- Don't test anything but chlorine.)
Here's the important question, once the sun hits your pool: what does the water LOOK like?
If it looks at all better, plan to put up to 8 gallons in tonight. But, test first -- don't add that much unless (a) the water looks better and (b) the OTO is no longer orange.
. . . . and Jeannie, I'm sorry, but we can't magically undo all the wrong things that have been done to your pool, under your pool store's instructions. We can help you recover, but when you hit yourself in the head with a hammer -- even when though the 'doctor' told you to do so -- you're gonna get a lump, and all we can do is try to take the hammer away, hand you some ice, and say, "don't do that any more, please!".
I get that. I don't expect miracles... but there has been absolutely ZERO change. Not even a little bit. I don't blame you or anyone but myself... but I am frustrated and I just can't afford 8 gallons of bleach a night. I'm sad.
21' round 10K gal AG pool; chlorine tabs; sand filter; pump; 12hrs; full Taylor Kit; utility water; android phone; PF:12
