Results 1 to 10 of 14
Thread: water is cloudy please help
    Default Re: water is cloudy please help
    You can swim whenever the chlorine is OK and the pH is between 7 & 8. The only hazard from cloudy water is losing track of someone -- drownings have occurred that way.
    Aug 2012
    Texas
    Wink Re: water is cloudy please help
    Thanks again! LOL... I do not think we will lose anyone in our Intex pool. Even the grandkids can touch! I'm hoping that MA clears it up by Saturday. I'm gonna put it in tonight before I go to Happy hour and then I won't worry about it till the morning. Have a fantastic weekend.
    18 round 5.5K gal AG vinyl pool; skimmer; cartridge filter; Intex pump; 10 - 12hrs; HTH 3 way cheapo Wal-Mart.; utility water; summer: none; winter: vinyl / water bags; iPhone; PF:22
    Thanks . . . but test your pH; don't let it get too low.
    Aug 2012
    Texas
    I defiantly will! Low and behold I get home and I can see blue squares!!! Still a little cloudy but I can actually see the bottom! Do you think I should still use the MA? Test says every things the same except the chlorine is a tiny bit lower 2 not 3. Let me go read up on your household bleach again because I have Clorox regular I know I read something about Clorox being tricky
    If it's clearing, why not wait till tomorrow. Except for chlorine, we generally tell people to avoid adding things if they don't need to do so.
    Aug 2012
    Texas
    Thanks for all you help the pool is crystal clear and grnadkids swam all weekend... Might need to add some water from all the splash out! Other than that everything tests good this morning! Again thanks for your expertise and time.
    glad it worked out for you . . .
