Results 1 to 10 of 14
Thread: water is cloudy please help
    Default Re: water is cloudy please help
    Thanks . . . but test your pH; don't let it get too low.
    Aug 2012
    Texas
    I defiantly will! Low and behold I get home and I can see blue squares!!! Still a little cloudy but I can actually see the bottom! Do you think I should still use the MA? Test says every things the same except the chlorine is a tiny bit lower 2 not 3. Let me go read up on your household bleach again because I have Clorox regular I know I read something about Clorox being tricky
    18 round 5.5K gal AG vinyl pool; skimmer; cartridge filter; Intex pump; 10 - 12hrs; HTH 3 way cheapo Wal-Mart.; utility water; summer: none; winter: vinyl / water bags; iPhone; PF:22
    If it's clearing, why not wait till tomorrow. Except for chlorine, we generally tell people to avoid adding things if they don't need to do so.
    Aug 2012
    Texas
    Thanks for all you help the pool is crystal clear and grnadkids swam all weekend... Might need to add some water from all the splash out! Other than that everything tests good this morning! Again thanks for your expertise and time.
    glad it worked out for you . . .
