Thread: Vogue Zenith HTH 6 way test results.
    Aug 2012
    canada
    Default Vogue Zenith HTH 6 way test results.
    Ok im not sure if my pool is considered an intex type pool. I am about to start doing the BBB method as soon as my initial startup chemicals are used up. I have all the BBB and the kem tek 22.5 dichlor is on order (2), the k2006c test kit on order as well.
    After adding conditioner this morning about 1lb i finally brought up my cya. let me know if these results are good or if i need to adjust anything.
    PH-7.2
    CL-5
    ALK-60
    CYA-35
    HARDNESS-140
    15x30 oval 10.6K gal AG vinyl pool; swcg; hayward s-180t sand filter; hayward ultra - pro lx pump; 10 - 14 hrs; strips right now but i want a k 2006; utility water; summer: solar; winter: none; android phone; PF:11
  1. HTH 5 Way Test Kit pH results?
    By Kschw in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 07-10-2011, 12:47 AM
  2. Test results vary between meter and drop test - not sure what to do?
    By west1745 in forum Salt Generators (SWCG) & other Chlorine Feeders
    Last Post: 07-29-2006, 04:27 PM
  3. First 234s test results and warning about pool stores' results
    By SoCalBoo in forum DPD-FAS based testing
    Last Post: 06-16-2006, 02:48 PM
  4. Any Vogue Pool Owners?
    By SherrySt in forum Above-Ground Pool Construction & Repair
    Last Post: 06-03-2006, 11:10 PM
