This isn't necessarily so. It depends on circulation patterns, pump run times, and more. What often happens on AG pools is that the water goes from green cloudy to gray cloudy.
As jwhouse notes below, you need to get the algae resolved first. You may not have a lot of choice about CYA levels, unless you drain and refill. 1. Test the water. 2. Kill the algae. 3. Fix any other URGENT chemistry issues. 4. THEN worry about ideal CYA levels.
This isn't completely necessary. Not everyone is at home during the day. Very large chlorine doses added each evening will do the trick, once you get the doses high enough.
But this IS completely necessary.You have to be very persistent.
Absolutely correct -- unless you have very low pH that could damage your pool, or very high pH that could interfere with killing algae. Then you need to do both at the same time.
