Thread: Small cavern under pool deck
    Aug 2012
    Riverside, CA
    Unhappy Small cavern under pool deck
    I am a disappointed new home owner.
    Not myself nor the inspectors caught the cavern underneath the piece of decking that butts up against the skimmer. Looks like their dogs dug under at a point. The seam or grout?? line has separated about 3-4mm on one side of the pie shaped segment and it appears to be raised maybe 2-3mm. I will provide pics when I get home. Sidebar on this is the cavern is a couple of feet away from the back fence/property line and this area of the fence has a crevice that looks like pool water actually ran for a while down at some point in time (maybe a few times) so this is a 3-4 foot embankment essentially that the edge of the pool deck is near. I have heard of mud-jacking and stabilization and taking off the deck segment and am so nervous about the potential of a breach and then the cost of course. This house turned out to be a fixer upper and this was never the intent.
    How can I get this little piece reinforced underneath so that I can further embark on the terracing at the fence line...or are they part of the same problem?
    If there is a thread addressing this point me there and I'll gladly read :-)
    Thx.
    Default Re: Small cavern under pool deck
    I doubt there are any threads that are directly relevant; repairs like yours tend to be somewhat unique.
    Posting pictures would be a GOOD idea. You can use Picasa, Flickr, Webshots or Photobucket.
  1. Water problems in small, small pool
    By MikeFromMesa in forum Pool Chemistry for Intex-type Pools
    Last Post: 06-10-2013, 04:53 PM
  2. in deck or on deck slide and diving board
    By bszaronos in forum Pool Equipment & Operations
    Last Post: 03-16-2012, 12:52 AM
  3. moss on a carpet covered deck (factory pool deck)
    By JETTA in forum Above-Ground Pool Construction & Repair
    Last Post: 09-08-2006, 08:56 PM
  4. Small pool
    By DONNIE in forum In-Ground Pool Construction and Repair
    Last Post: 07-08-2006, 10:13 AM
