Sounds like a suction leak. If it is, it will probably get worse when you close the main drain. And, a suction leak will definitely impair vacuuming.
However, using a 1 1/4" hose, instead of a 1 1/2" will mess vacuuming up, as well. Also, stiff vacuum heads sit too high above the surface, and not create the high flow / high suction necessary for good vacuuming. The ProVac heads conform to the pool surface much better than any others I've used.
