Results 1 to 10 of 14
Thread: copper tubing?
    Jul 2012
    Mexico, Missouri
    Default copper tubing?
    I don't know what the commercial heaters use in their heat exchangers, but I suspect it would be stainless steel.
    Would there be a problem with using copper pipe in a home built solid fuel heater? If there are serious cons to this, I do have another method in mind, it just involves a lot more work, along with lower efficiency.
    Would copper tubing require keeping a really close watch on pH? Would I be introducing copper ions into the pool? I've seen via the internet, many examples of people using copper in home built heaters, but with my lack of knowledge in this area, are they asking for green, copper laden pools?
    Thanks for any info you can provide!
    15' round 4.8K gal Intex AG pool; Intex 633 pump with twin canisters (2500 gph main filtering); Unicel 5315 filter cartridges; Intex 637 pump w/o filter (1000 gph heater circulation); 4hrs; K-2006; utility water; PF:24
    Jul 2012
    Mexico, Missouri
    Default Re: copper tubing?
    I guess no one has any thoughts on this?
    You can use copper if you keep the pH between 7 and 8, and don't use salt.
    The heat exchangers in commercial pool heaters are copper, just like they are in residential units. However, salt-compatible residential units have cupro-nickel exchangers -- stainless steel is a poor conductor and is not used.
    NOTE: this is NOT a recommendation that you actually DO any of this. Building a heater is potentially life-threatening! It's surprisingly easy to build a water bomb -- when home water heaters explode they often level the house and kill everyone inside!
    Here are 2 videos you should watch, before you go further:
    50 Gallon water heater explosion
    Mythbusters Water Heater Explosion
    Jul 2012
    Mexico, Missouri
    Yes is would be dangerous if I used a closed container, without a temperature/pressure relief valve. Obviously, in both the videos, those key pieces of SAFETY equipment had been removed and the hole plugged.
    If you have ever seen a properly equipped tank go into thermal runaway, the T/P valve lets loose well before an explosion can happen.
    In this case, YES, I would plumb in a T/P valve. In addition, NO fire would be lit without water flowing through the heat exchanger, and would continue to run well after the fire was out. Under no circumstances would this be left unattended. There would be no pressure vessel (tank) involved in this build, if I do decide to go through with it.
    As I said, building a heater is potentially life threatening. You seem familiar with the safety devices typically used on water heating systems, so I presume you can experiment safely. But I didn't know that when I posted. There have been 3 or 4 prior posters this year with some other DIY pool heating system ideas and not one of them had a clue about safety.
    When I post as I did above, I'm not only writing for you -- since you hadn't mentioned T&P valves, etc -- but also for all the lurkers who will Google "DIY pool heater", and end up here.
    Jul 2012
    Mexico, Missouri
    I agree with your reasoning behind the reply, and I appreciate the reminder. I like the fact you care enough to post that kind of safety warning.
