Results 11 to 14 of 14
Thread: copper tubing?
    Default Re: copper tubing?
    Uhm. Interesting?
    Not sure what to say. It shouldn't be too dangerous, since if the copper overheats, the PVC will collapse before there's any sort of pressure build up. Plus, it doesn't look like you have any valves that would allow a pressure increase to occur.
    Not sure how durable it all is, though. Any joints you have that are exposed to the fire are unlikely to last long, unless you used high temp silver solder. If you have calcium in your pool, and get build up in the coil, it can insulate the pipe from the water enough to allow the pipe to over heat. And . . . copper is not especially resistant to combustion gas effects.
    But, time will tell.
    Jul 2012
    Mexico, Missouri
    Uhm. Interesting?
    I do have one valve on the return side, to be used only when removing the apparatus at pool closing. It remains fully open otherwise.
    I really don't expect this to last more than 1 or 2 seasons in it's present configuration. This initial build is intended as a "proof of concept", to see how well it will work.
    I used lead free potable water (95.6%Sn 4%Cu .4%Ag) solder on all copper joints. With water flowing through the pipes, I doubt that the joints will get anywhere near the melting point of the solder, even with a 10* rise in water temp from suction to return.
    One other problem that I probably will need to address is the tendency of creosote to condense on the tubing. This was fully expected. Knowing that creosote is acidic, but not knowing how far down the scale it is, leads me to expect failure of the tubing itself within the 1-2 season life expectancy. At least this will give me enough time to procure thin wall stainless tubing, along with the means to either bend it or braze fittings into the shape I want.
    I'm not sure I'll have much of a problem with calcium build up in the tubes, before the creosote corrodes the copper to the point of failure. Fill water has 180-240ppm calcium, depending on what week I check. I'm not sure why it tests differently one week to the next. Probably which well the water co drew from that week. For our domestic hot water, I've found that I need to clean our gas fired water heater only every 2nd year, so I think I can assume that the heat exchanger in the pool heater won't have too much of a problem with this before corrosion failure.
    15' round 4.8K gal Intex AG pool; Intex 633 pump with twin canisters (2500 gph main filtering); Unicel 5315 filter cartridges; Intex 637 pump w/o filter (1000 gph heater circulation); 4hrs; K-2006; utility water; PF:24
    Quote Originally Posted by Charlie_R View Post
    Not necessarily a correct assumption.
    In your water heater, scale prevents heat from escaping as easily, but the scale stays wet (unless you hear popping noises) and so the heater element is temperature limited by the boiling point of water.
    This may not work out as well with tubing exposed to uneven fire box heating, compared to tubing exposed to very even heat element heating.
    BTW, you can prevent having to replace heater elements by using a low watt density Inconel sheathed element like this one:
    Camco 4500W 240V Screw-in Water Heater Element -Ultra Low Watt Density
    Camco 5500W 240V Screw-in Water Heater Element - Ultra Low Watt Density
    Years ago, when I was a plumber doing commercial service work, these were hard to find. But thanks to Amazon, they are now available to everyone. In most installations, this is a life-of-the-heater replacement. Because of the much larger surface area, scale formation is greatly reduced. And, because of the inconel sheathing, the elements don't fail even when they do get coated with scale.
    Jul 2012
    Mexico, Missouri
    This is true, and works the same in gas or electric water heaters. As stated above ours is a gas fired, and will remain so as long as gas is cheaper than electricity as applied to heating potable water, not to mention the differing inefficiencies of both.
    Yes, the uneven heating is a concern of mine. What I have done to reduce -- cannot eliminate -- this, is baffles to direct the hot gasses around the tubes to attempt to even out the heat each is subjected to.
    I have used these where former employers had rentals with electric tanks. I agree that they are worth the slight extra expense, at least in my area. In only one case did I ever see one of these fail, an upper element, and that was attributed to the tank losing water when the water supply to the house failed while it was unoccupied.
    Would it be too much of a stretch to assume that the calcium scale would make it's presence known by a reduction of CH in the pool water? In my ignorance, I have the idea that the calcium in the water would have to precipitate out as it encountered the heat in the tubes, attaching itself to the source of that heat. I don't know that this is what happens in a water heater, but that is my suspicion. In so doing it should manifest itself with a change downward in the tested levels.
  1. New member- chemical tubing question
    By Penypool in forum Commercial Pool Users, Managers & Workers
    Last Post: 06-13-2013, 02:05 PM
  2. Pool pump tubing - PEX?
    By ArmyChief in forum In-Ground Pool Construction and Repair
    Last Post: 07-29-2012, 08:19 AM
  3. CL2 migration through poly tubing
    By pmeloy in forum The China Shop
    Last Post: 11-26-2011, 01:49 PM
  4. Copper??? Nooooo!
    By shadowman in forum Dealing with Algae & Slime
    Last Post: 05-30-2009, 01:57 AM
