Thread: Algae on pool walls
    Aug 2012
    Pennsylvania
    Default Algae on pool walls
    Water is clear and not green. Algae is building up on the walls in the deep end. The algae does not brush off anymore. Any suggestions?
    Default Re: Algae on pool walls
    Please complete the Pool Chart:
    Pool Chart Entry Form
    That will give us enough info get started.
    Meanwhile, if you are treating your pool with chlorine, add 3x your normal chlorine shock dose this evening and next. Tomorrow evening, brush after shocking.
  1. High Chlorine but still some yellow Algae on walls
    By stevetuck in forum Dealing with Algae & Slime
    Last Post: 06-05-2012, 09:48 AM
  2. New maintainer with algae on walls
    By SurfaceDreamer in forum Dealing with Algae & Slime
    Last Post: 05-25-2012, 03:49 PM
  3. Yellow algae on walls
    By pinchedc in forum Dealing with Algae & Slime
    Last Post: 04-17-2012, 02:49 PM
  4. Can pool be safe with some black algae in walls if water is super clear?
    By inletyachtman in forum Dealing with Algae & Slime
    Last Post: 06-23-2011, 04:17 PM
