Thread: ps234 test results - first post
    new jersey
    Default ps234 test results - first post
    I have been visiting this site for 3 years -- learned a lot. I finally bought the test kit. My results are
    fc-2.5
    cc - 0
    ph - 7.2
    alk - 70
    cal - 190
    cya - 25
    temp - 83
    35,000 gal 20 year old gunite.
    I bought a heater 2 years ago and in the documentation it recommends lower calcium because "things" can grow in the heater and it won't be covered. so I try to run the calcium around 200. If I bring up the ph a little will the alk go up or down (I can never remember everything I read at this site).
    mbar's Avatar
    Ashland, PA
    Default Re: ps234 test results - first post
    If you want to bring up the ph, use Borax, it won't raise the alk. much, if at all. But since you have low alkalinity - you want it between 80 - 120, you can add baking soda - it will raise both ph and alk.
    Here is a link for the bleach calculator, click on the top more calcs) and there are other calculations, there is one for ph and alk
    http://www.hal-pc.org/~mwsmith2/BleachCalc262.exe
    Northeast PA
    new jersey
    Thanks my ph went up to 7.5 so that looks good --
    If I want to increase the calcium a little what do I add --- I really don't want to get the powder chlorine with the calcium but if that is all I can do that I can use some pucks.
  1. My pS234 test results
    By lskeate in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 05-14-2008, 12:16 PM
  2. First Test Results Using PS234 Kit
    By aeroeric in forum DPD-FAS based testing
    Last Post: 07-05-2006, 08:56 AM
  3. PS234 Test Results
    By bxb21 in forum DPD-FAS based testing
    Last Post: 07-03-2006, 10:41 AM
  4. PS234 1st Test Results
    By DM in forum DPD-FAS based testing
    Last Post: 06-22-2006, 07:47 AM
  5. 1st PS234 Test Results
    By Cannonball in forum DPD-FAS based testing
    Last Post: 06-04-2006, 02:46 PM
