Results 1 to 10 of 11
Thread: Zero FC Pool is crystal clear
Threaded View
    Aug 2012
    Suffolk County, New York
    Default Zero FC Pool is crystal clear
    Hi,
    As you know this is my first post. I've been a pool owner for 18 years and never had a problem like this.
    Background: This past winter was uncommonly warm. With the porous Loop-Loc cover, I'm accustomed to a green pool when opening it, but this year it looked like pea soup and smelled like a sewer. Initial CYA reading was 0.
    After a lot of work I've gotten it clear and added ~24oz of Polyquat 60%.
    Now, the pool specs:
    27,000 gallon, 18X36 inground vinyl pool, DE filter, Hayward off-line chlorinator, heated with natural gas.
    Pool water is ~80F and clear. Taylor K-2600 readings:
    FC=0; CC=0.8; pH=7.4; Alkalinity=110; Hardness=170; CYA=75
    Circulator is running 24hrs. Chlorinator is set to Full with 3" tabs.
    I have been adding ~2.8 gal of 6% plain bleach each evening, but by morning my FC=0.
    Even with the Polyquat, if I'm away for a few days, I will sometimes see a small amount of green algae, until I dump several gallons of bleach and brush the pool.
    I’m grateful that the pool is clear and swimmable, but what should I do now.
    Thank you!
    Peter
    18x36 rectangle 22.8K* gal IG vinyl pool; trichlor feeder, Hayward CL220; Hayward DE-3600 DE filter; Hayward C48K2N143 1HP 1 speed pump; normally 7 hours - now 24 hrs; gas heater; Taylor K-2600 FAS-DPD; utility water; summer: none; winter: mesh; android phone; PF:5.3
