Thread: Intex rectangular ultra frame 24 x 12 buckled u shaped legs
    Jul 2012
    North Carolina
    Default Intex rectangular ultra frame 24 x 12 buckled u shaped legs
    We had the pool professionally leveled and put 3 inch blocks under the u shaped legs. The mistake I made was not putting the blocks horizontal with the bottom of the "U"; instead I put them vertical so the blocks would be centered in the middle of the 'U'. We had torrential rains last night and the pool filled up and buckled 6 U shaped legs on one side. Intex says these legs are out of stock. Anyone ever straighted bent U shaped legs successfully? So frustrated with myself, the rain and the pool!!! Thanks in advance.
    Default Re: Intex rectangular ultra frame 24 x 12 buckled u shaped legs
    Hmm-mh. You could probably make new ones with 1 1/4" EMT and a bender:
    http://constructionsupplycentral.com...t-conduit.html (But check Lowes & Home Depot)
    Bender @ Amazon
    Handle @ Amazon
    Cutter @ Amazon
    You can buy a 1" and a 1.25" EMT coupling, to take home and compare to your tubing sizes. And, you can hire an electrician to fit the tubing, instead of DIY.
    Jul 2012
    North Carolina
    Thanks for your responses. I really think there's no hope for these legs. By the time this posted as a new thread, I have found someone who is selling their old pool on Craig's list; so I may end up with some used legs. Still it will be 18 used legs for the price of 6 new legs and I can get them this week.
    Sounds like a better solution, to me.
  1. 16X48 intex ultra frame
    By td51902 in forum Pool Chemistry for Intex-type Pools
    Last Post: 06-24-2014, 07:35 PM
  2. Is jacking up the legs of Intex Ultra Frame safe?
    By Annieski in forum Intex-type Pool Setup & Operations
    Last Post: 07-01-2013, 07:57 PM
  3. Need dimensions from someone with Intex Ultra Rectangular pool.
    By zanemoseley in forum Above-Ground Pool Construction & Repair
    Last Post: 07-23-2011, 03:19 PM
  4. Who has an Intex Ultra Frame 24' pool?
    By jkoch in forum Above-Ground Pool Construction & Repair
    Last Post: 06-27-2010, 11:54 PM
