I doubt it will matter for this.
30' round 22K gal AG vinyl pool; skimmer tabs and GV Bleach; Hayward SD60 sand filter; Pentair 1.5 HP pump; hrs; ; utility water; summer: none; winter: none; K-2006 Test Kit ; PF:5.5
Thank you everyone for all the great suggestions. I'll let you know how it goes.
I found this:
http://www.itwconsumer.com/projects/...g%20PVC%20Pipe
Says it will fix leaks in PVC.
Anyone have any experience using this?
I have never had any putty epoxy last in a pressure side leak.
I have found only one product that works to repair PVC and stands up well to pressure side leaks. It is called Plast-aid. I have used it successfully several times now and have not had it fail but it does take a bit of practice to get used to. It cures in about 15 minutes to repairs are fast.
http://www.plast-aid.com/
Their website has some excellent demo videos of how to use it.
The nice thing about it is that you can apply it as a glue or a putty so it can fill a crack. My only advice is use it outdoors if possible since the smell is really strong until it cures.
Thanks. I'll check that out.
I also did a Google search and found this:
3M 08101 Structural Adhesive worked for me for PVC pressure piping. It's urethane, not epoxy. In shear adhesion test with rigid PVC,
the PVC breaks before the adhesive bond (2000 PSI).
For even more strength, fiberglass cloth can be embedded in the patch. I patched our sand filter base which was broken into 3 pieces and used fiberglass mat for reinforcing.
Wear disposable gloves, and plan your application, because it sets rapidly.
http://solutions.3m.com/wps/portal/3...glXQ8JG35VSMbl
http://www.handsontools.com/3M-08101...0-reviews.html
Back to top
If you have a friend who is a pipefitter, most outfits today have a plastic welder and PVC rods. Cracks like you describe can be partially ground and then refilled. It does require a deft touch however, since there's a pretty fine line between melting PVC and burning it.
PoolDoc / Ben
Thanks for all the great suggestions.
I decided to give the Plast-Aid a try. I'll report back after I receive it and do the repair.
Get the middle or big kit so you can practice with the stuff first. Make a marble (the vid is on the website) so you can get used to it. I have not only used to to repair pvc, I have also used it for countless repairs on my RV
