I just bought the test kit from amazon that you said to get. I use the Chlorine drops from walmart hth brand.
Thanks Aaron
Thanks Aaron
18 round 6.7K* gal Intex AG vinyl pool; skimmer tabs; "A" cartridge filter; Krystal clear Model 635t 1 speed pump; all the time hrs; HTH 6-way; K2006 on order ; utility water; summer: none; winter: pool is down in the winter; android phone; PF:18
+ Post complete test results using the 6-way.
+ Add 2 gallons of PLAIN 6% household bleach every EVENING till the algae changes color;
+ The following evening, add 2 more gallons and BRUSH the pool
ALTERNATIVE:
+ Read the Intex EZ Start recipe; get what you need to follow it.
+ Drain your pool; refill to the 1 foot level.
+ Add 2 gallons of bleach and brush around the pool
+ Clean your filter.
+ Finish filling and begin following recipe.
Recipe: http://www.poolforum.com/pf2/showthread.php?17055
PoolDoc / Ben
Ok didn't receive the test kit yet.... I did the borax and the bleach around 10am and when I got home 6pm it was not as green. So I scrubbed the sides and bottom and added another gallon will see how it looks in the am. Will test with the walmart test kit for now. Can't see the bottom as of yet. How do I maintain this after I get it clear?
I didn't do the start up plan because I didn't know that this forum existed until I had a question about my filter. It's working and I want to thank you for all the input. It's been helpful. I like your way of thinking better than pool stores.
For now the pool is not as green as it was but still cloudy. Also the sides and bottom are not slimy so that seems good. I didn't get a vacuum yet so what do you think I should get to clean the bottom of the pool?
Thanks Aaron
Just stay with the recipe I gave you.
You will need a vacuum set. Period. Also, buying Unicel cartridges will help; the Intex OEM don't seem filter algae particles. I'll put links for the Unicels and a vacuum set. You'll need to get the Unicel's online, but you may be able to find a vacuum set on clearance at Walmart, etc for a lot less.
Ben
+ The OEM cartridges in Intex / Summer Escapes / etc. filters are not high quality. The Intex manuals recommend replacing them completely every 2 weeks. A BETTER option is to replace them permanently with 2 - 3 Unicel cartridges, and rotating them through a cleaning solution. Properly maintained, the Unicel cartridges will last all season AND will filter better. So even though they cost more per cartridge, they cost less per season! Learn to maintain them, by reading this post, Cleaning-your-Cartridge-Filter-wiithout-Damaging-It!
But, purchasing them is tricky. Amazon does not consistently stock them, and some of the 3rd party sellers are charging high prices and/or high shipping. So, check the Amazon link, but watch out for the prices and shipping costs.
It would be nice if you could just buy them elsewhere, but many of the online pool stores are listing Pleatco or other Asian made low quality filters, as "Unicel C-4607 type" or "fits Unicel C-4607". So shop carefully!
Here are the Amazon links:
Unicel C-4607 Replacement Filter Cartridge (Easy Set Size A or C) @ Amazon
Unicel C-5315 Replacement Filter Cartridge for 15 Square Foot Intex B Filter @ AmazonPoolmaster 27514 Classic Full View Triangular Vinyl Liner VacuumOne caution: it may be necessary to get some sort of adapter to connect vac hose to the skimmer or pool. Possibly, something like this
Hydro Tools 8365 8- to 16-Foot Adjustable Fluted Premium Fluted Telescopic Pool Pole, White
Hydro Tools 1-1/4-Inch Diameter With Swivel Cuff Pool Vacuum Hose
Intex Vacuum Tube Adaptor
However, I am NOT recommending that, because I'm not sure it's what you'll need, or even if you will need it. Also, I hate to see a $9 shipping charge with a $9 item -- that's not a ripoff necessarily, but I'd rather find a better way.
PoolDoc / Ben
Hello,
This morning my pool is not Green Yea!!!!!! But it's still cloudy. How do I get it clear? I did buy the replacement filter cartridge from amazon. I should get it saturday.
So now what do I do clear up the cloudy mess..... I did get a vacuum and already vacuumed the pool. My kids want to swim I told them not yet!!!! Let me know how to clear up the rest. When I get home I will do a test for the PH.... Thanks again for the help!!!!!
Continue with the high chlorine levels and also run your pump 24/7 right now, cleaning the filter as needed. The chlorine will kill the algae but it is your filter that will filter it out.
Let 'em swim!
With your chlorine high, the only dangers are faded swimwear (from the chlorine) and a disappeared kid (from the cloudy water). Just keep a good eye on them, and have them wear old suits, and let them in!
