Results 1 to 10 of 15
Thread: MY Intex pool is green and cloudy
    Jun 2012
    PA
    Default Re: MY Intex pool is green and cloudy
    Pooldoc
    I understand
    Readings
    ph= 7.8
    cya = 30
    alkalinity test 20
    chlorine test (25ml 0.2ppm) 20ppm (fc)
    I can see the bottom it's still a little cloudy but I can see the bottom and I brushed it today not much on the bottom....
    Is it ok to swim? do I put the chlorine drops back the skimmer?
    Do I still need to add bleach until crystal clear?
    My kids are 8 and 4 so they want to swim today 8-24-12. JUst didn't want them to get sick....
    Thanks for all your help..... I am learning so thanks for being patient.
    Aaron
    18 round 6.7K* gal Intex AG vinyl pool; skimmer tabs; "A" cartridge filter; Krystal clear Model 635t 1 speed pump; all the time hrs; HTH 6-way; K2006 on order ; utility water; summer: none; winter: pool is down in the winter; android phone; PF:18
    Low chlorine, not high chlorine, makes kids sick! Extremely high chlorine can be irritating, but won't make anyone sick.
    Your pool is fine for swimming, but I'd have them wear old swimsuits. New ones might fade.
    Regarding bleach, high chlorine will kill algae but will not make your pool crystal clear: filtration does that.
