Thread: Replacement Light
    Aug 2012
    Philly PA
    Default Re: Replacement Light
    bump - any thoughts on what will fit as a replacement light assy?
    18x36 rectangle 19.4* gal IG vinyl pool; skimmer tabs; Pacfab DE filter; 1 speed pump; 8 hrs; utility water; winter: vinyl / water bags; android phone; PF:6.2
    I'm not 100% sure but any light should fit the existing niche, even between brands, the niches are fairly uniform and will accept a new light housing.
    Have you talked with Hayward?
    If you need help removing the old housing & cord and installing the new one - or, if you actually need the niche replaced - get back to us.
