Re: high ph/ alkalinity and green pool
If you find that your filter isn't catching all the algae, you can try putting a little bit of DE (like they use in DE filters) in through the skimmer and let it coat the sand (just use enough to create a 1 psi rise in your pressure). That will help the sand catch smaller particles. It's a trick that the other 3 mods have all used in their filters.
