Results 1 to 10 of 17
Thread: Liner slipping
    Jul 2012
    Ontario, Canada
    Default Liner slipping
    Hey -
    I'm in the process of installing my 15x30 AGP.
    I started to slowly fill it with water from a hose, had about 8" and the liner popped out on one end.
    THe instructions say to put the seam of the liner on the cove. It does not say how much liner to overlap over the side. It's not a jhook liner.
    The pool place said they typically put the same of the liner up the wall alittle bit and overlap the liner about 6 inches on a hot day so it'll stretch lots.
    I'm guessing they know what they are doing, but why would this happen? The liner is held on by these long U shaped clips, then the top plate.
    Any insight is appreciated.
    THanks,
    Brad
    Default Re: Liner slipping
    Ted knows liners; I asked him to look.
    As long as the overlap was ~ equal all the way around the pool, all is fine!
    If the liner will no longer go over the wall and be held in by the retaining piece, there is a problem and you need to stop filling the pool.
    Please don't worry about an even overlap outside the pool - what's most important is that the liner inside the pool is wrinkle free.
    Please let us know how it all works out - I'm hoping that you'll be swimming tonight
    Jul 2012
    Ontario, Canada
    I'm not sure I follow.
    I was filling the pool, and the liner 'slipped' off on one side. Once it did that, I could no longer pull it back over. I stopped filling the pool and drained it this morning.
    You can see my photo's here:
    http://www.poolforum.com/pf2/showthr...all&highlight=
    Basically the liner slipped off to the right of the ladder in this picture:
    The liner is wrinkle free, on the floor for sure.
    In the same picture, you can see some wrinkles in the wall sections. Is that what you mean?
    The overlap wasn't equal all the way around. One end I had about 6" let's say, on the other I had about 2".
    So I guess I should make it 6 and fill it when it's sunny?
    Thanks for the reply!
    Brad
    Feel free to post a full set of photos, as you go. It will help others, later.
    Neat application of the folding ladder . . . I've got one, but that never application never occurred to me. (I've never installed a metal wall type AG pool.)
    Jul 2012
    Ontario, Canada
    Yeah, the ladder worked well, especially because the depth of the pool was lower then the ground, so it worked well.
    So now my liner is consistently 6" overlapped around the pool. I put about 2-3" of water in and will start putting more in tomorrow once it's sunny.
  1. J-channel holding liner in corner broke off, liner is sagging
    By TRHOD12 in forum In-Ground Pool Construction and Repair
    Last Post: 05-09-2011, 04:41 PM
  2. Wrinkled Liner and Water Behind Liner
    By rbposey in forum In-Ground Pool Construction and Repair
    Last Post: 09-26-2009, 05:40 PM
  3. Liner slipping out of coping
    By daisy11 in forum Pool Equipment & Operations
    Last Post: 05-11-2007, 04:14 PM
  4. Liner Slipping from Coping
    By nutmegax in forum In-Ground Pool Construction and Repair
    Last Post: 07-22-2006, 12:55 PM
  5. Do I need "Liner Lock" for Beader Liner
    By Aranon in forum Above-Ground Pool Construction & Repair
    Last Post: 04-30-2006, 12:04 AM
